- Mon Nov 09, 2015 6:53 am
#357528
So I have my Rebuilt D15B7 with Intake and exhaust, and I'm about to drop an A6 cam into it. I know the lobes are a bit more aggressive and I was wondering if there were any throttle bodies out there that might be able to give a little bit more air into the mix. I know the D15B7 has a 56mm TB, so I'm wondering if there are any D series or B series throttle bodies that are 58 or 60mm and also have the firewall-mounted MAP sensors. I'd like to avoid re-wiring everything if possible. Just looking to squeeze a bit more juice out of this B7 someone let me know if they know of any throttle bodies that will work for my application
- Mon Nov 09, 2015 10:59 pm
#357540
bump
- Tue Nov 10, 2015 4:14 am
#357547
Here's a list of D series TB's:
viewtopic.php?p=502
Suspendedhatch has some good tech (as always) that might be worth researching.
viewtopic.php?p=502
- Wed Nov 11, 2015 5:30 am
#357557
The D15B7 throttle body is the same as the D16Z6's.
I know some people use B16(60mm) throttle bodies, but I doubt it's worth much or you'd hear about it more.
