- Thu Nov 22, 2012 4:28 am
#320598
I went to get my 2000 lx e checked today. Well I got a CEL on and its a code 1. When the dude hooked it up to the sniffer in failed almost immediately. I have high hydrocarbons and extremely, extremely high N.O. gas. I replaced the. Down stream O2 sensor about a month ago and noticed the cat looked munched. Does anyone have ideas to pass echeck?I am think if I do the manifold and converter along with a new up stream O2 sensor that would fix it.But I'm not sure
- Thu Nov 22, 2012 4:53 am
#320604
what kind of miles do you have? Your manifold should be fine.
- Thu Nov 22, 2012 5:24 am
#320613
Ah sorry to hear that those are pricey
rustyrex wrote:174xxx. The manifold is fine but the cat and manifold are 1 piece.
- Thu Nov 22, 2012 5:27 am
#320616
wow whos it made by?
rustyrex wrote:I actually found a brand new one for $188 I'm stoked on that lol
- Thu Nov 22, 2012 5:35 am
#320619
i've boughten stuff from there before. But i would recommend walker or bosal for after market cat's.
rustyrex wrote:Dorman. I found it on www.rockauto.com
- Fri Nov 23, 2012 2:09 am
#320671
one big difference that i found is to get the engine and exhaust hot before doing the test. I failed because the car was barely warming up (I live 2 miles from a station).
The worker said to beat on it first and it should pass. So I took back roads there at 55 mph in 3rd and 4th gear - passed no problem without changing anything on the car.
- Fri Nov 23, 2012 4:37 am
#320675
Ive never heard of that happening before but I'm sure it can't be good...
- Fri Nov 23, 2012 4:40 am
#320676
Wait, just noticed this was for a 2000 civic which is obd2. They will fail automatically with a cel but they only put them on the scanner, Not the Dyno.
What is the code 1 for? Fix that and youll be good - they should not even have put it on the Dyno.
- Fri Nov 23, 2012 5:15 am
#320679
They checked it with the scanner and the obd wasn't ready yet. I reset the ecu like 10 minutes before I went. Once it came up that it wasn't ready they put it on the rollers. Once a 96 or newer car fails the roller test it can not be tested with the scanner until it passes the roller. Code 1 says the voltage is either too high or too low for the primary O2 sensor.
- Fri Nov 23, 2012 1:42 pm
#320698
I'd try replacing the upper o2 sensor and yeah, they know if you reset it right before you come in. You'll have to drive like 20 miles or omething like that before getting it tested.
- Fri Nov 23, 2012 4:29 pm
#320710
You repeatedly stated the cat converter is fried. Is it not obvious to replace that?
The bad O2 sensor will cause you to run rich or lean, either of which will destroy your cat converter given enough time.
