- Tue Mar 30, 2010 1:22 pm
#184565
I'm sorry, I missed before when you mentioned your civic was 6th gen.
It will be easiest then to use the P2P ecu and keep everything OBD2.
The cam timing is different between OBD1 and OBD2, so you may want to use an ajdustable cam gear on the d16z6 to perfect the timing.
OBD2 uses a knock sensor, secondary 02 sensor, and crank sensor. D16z6 does not have these, so you will have check engine errors.
The way around this is to get a P28 ecu and chip it with software such as Hondata, Neptune, AEM etc...
Then get an OBD1 to OBD2 conversion harness to use the P28 ecu on your obd2 harness.
Also the distributor harness and fuel injector clips will be different.
Putting OBD1 engine in OBD2 car is much more difficult than OBD2 engine in OBD1 car.
iserb wrote:TRUTH??? you know that I am right now for the last 2 months - smiled))
but what about fuel cards, point of VTEC, compression and oter .... just install? olug and play ))))?
You advise to take the P28 OBD1 1995, or P2P CIVIC EX OBD2B 1999 (it was my AT gear, but it have immobilazer)?
If so all is well then I'll do it soon!! HURRAY!
