- Thu Dec 06, 2012 8:22 pm
#321739
Thanks for the tip I should be able to get fiat coupe breaks easy enough by edit them do you mean get the machined down to size???
fago88 wrote:Ecc0 wrote:Know I've been away for a while but the progress on your build is amazing looking really good and loving the ep3 cali idea might have to start shopping for some myself. What 300mm discs are you using as ep3s are 5 stud???
you can use EP3 disks an drill new holes....what I do not prefer!
Or you can use some Fiat Coupe Turbo discs ...
specs:
4x98, 305mm disc and 59mm centering.... you have to edit them a little bit but I think thats better then drilling new holes
unfortunately the are no Discs with 4x100 300mm and 64,1mm centering
