- Fri Feb 13, 2015 11:33 pm
#351876
teal_dx wrote:I'm surprised someone doesn't make skid plates for our cars.
BTW, I think your coupe is ROTM worthy
I did some research back when I was in the middle of the swap and there was a company that was going to make them. They actually did make some, but there was no interest so they scrapped it. All I have seen too are homemade ones.
I wonder though if a large skid plate would effect the cooling. You would think that air over the oil pan would play some roll in the cooling of the engine. I guess one could drill holes or direct some air to the pan some how.
BTW, I think your last sentence was the highlight of my day! Thanks!
I have thought about submitting it, and I probably will, when I get some better pics. I have been planning on going to a park down the road from me and having a photoshoot. but i probably won't do it until it gets warmer so i can take the daughter there to play as well.
Thanks again man!
EconoBox wrote:That oil pan is getting close to the ground. My H22 swap was similar and it does make you cringe every time you hear a scrape under the front end.
I hear the h22 swaps are bad too. One guy was telling me it is worse than a k swap, but I wouldn't know to be honest.
The big problem with the k series in these cars is the pan hangs out in front of the front tires. It's a speed bump nightmare. The pan will hit the bump before your tires do to "lift" it out of harms way. My worry is it's an aluminum pan. It's not going to dent lol.
#RoseburgStrong #IamUCC
