By boos-tit
#112975 i bought a new t3/t4 turbo yesterday and its equipped with an internal wastegate. i dont know if i should save some money and keep the internal wastegate? or should i buy an external. how much boost can i run witht he internal? any extra info? thanks
By d-mon
#112976 internal waste gates are usually adjustable, up to ~ 10psi.
using a simple manual boost controller you could go higher.
By colpitts
#112986 or play with the springs to make the gate hold more pressure.. ie change the spring for a stiffer one..
By boos-tit
#113101 well im only planning on running like 8-10 psi on my b16b. should i just keep it?
By boos-tit
#113207 thanks a lot guys :D
