By mid_egf22
#355168 After looking through about 10 pages I didn't find much setups and info. Just mainly people asking noob questions like how much psi this or that is safe on my engine or what turbo etc etc etc
If you got a turbo setup post it up. Give everyone an idea of what they should do for their future set ups and how your particular turbo spools on your setup. Each setup will be different based on, BUT NOT LIMITED TO TUNING, but will give a good idea to most in search of a setup. Spools times are really important as we know most of these setups are for D.D.
Example:
D15B7(UNTOUCHED BOTTOM AND TOP)
Greddy TDO4-H
GREDDY LOG MANIFOLD
2.5" DOWNPIPE
PUMP GAS
SPOOLS @ 2,250 RPM
MAX BOOST OF 8PSI AT 3,100 RPM.
1/4 MILE: 14.0, SEMI BALD TIRES
By mid_egf22
#355184 nobody? anybody?
#355192 Here's my boosted sohc setup:
Engine:
D16z6
SRP 75.5mm forged pistons
Eagle Rods
ARP Head studs
1999 D16y8 intake manifold
knockoff AEM fuel rail
AEM fpr
DSM 450cc Blue top injectors + resistor box
Motorola 2.5 bar MAP
Walbro 255 LPH
stainless fuel line, -AN fittings, inline fuel filter
Custom K&N for clearance
Auto to Manual conversion mount
OEM mounts urethane filled
Turbo:
Garrett T3 .60/.48 60 trim internal WG
Cast manifold
2.5" Spoolin DP
3" Thermal cat back
2.5" piping & FMIC
Hallman manual boost control
knockoff HKS BOV
Function 7 -AN downpipe flange & fittings
Oil Sandwich Plate Adapter
Custom K&N Air Filter
P28 chipped with Hondata S300
I've been building it since 2008 and haven't raced it yet :facepalm: :facepalm: I'm such a slacker.
By mid_egf22
#355263 Sounds like one good build you got going on there. Any chance you have dyno numbers and spool times?
By HeikDiesel
#355333 I'd care more about trap speed than ET and whp.
