By kc12305
#284686 Image
so im going to start here with new pics is this were im going to wire in my realy box for my dsm 45cc injectors
#284692 Hey saw your last post on previous page. I don't have a smart phone so I can't text you all the photos. What about printing out the DIY if you're looking for a way to have it with you when working on your car.
And yep, that's the plug to use for the resistor box. Be sure to check the wires with a test light, honda didn't put the pins in any particular order since it is only a junction plug.
By kc12305
#284834 Ok thanks thats,exactly what I was looking fof now thw ext step would be to wire the injectors in
By kc12305
#284868 on my turbo kit it didnt have the bolts to put the down pipe on it what would the bolt size be or what can i use to replace them any ideas
#284869 Easiest thing to do is to take it to the hardware store with you and test fit some bolts there to be sure you buy the right ones. I can't tell you how many times I walked into lowed with a car part to be sure I found the correct size bolts/nuts
By kc12305
#284870 so when i plug the relay box in that plug next step is wire the injectors ?
also how does your turbo kit work exactly and did you change your head studs and get head work done or no cause i was told to but i dont think i need it cause the motor has only 60-70k miles on it
here is a pic of the turbo i got yaya Image
and im not sure what this middle piece is exactly between the BOV and the BOV pipe
and here is the kit put together roughly
