- Wed Jul 30, 2014 5:23 am
#347513
Hey guys, been a while since I've been on here. Finally getting turbo gear together to go turbo. I'm doing this on a budget, trying not to cut corners where it really matters. I'm still learning about this stuff. What do you think of what I have so far? My goal is to hit 300whp on a dynojet. Dyno tuned by local tuner on Neptune rtp, maybe 14psi?
Plan to rebuild my b18b1 with:
OEM valve seals
OEM piston rings (hone cylinders?)
OEM head gasket
OEM timing belt
OEM water pump
New valve cover gasket
ARP head studs
Valve lash adjustment
Considering rebuilding myself or taking it to a knowledgeable guy.
I'll have a spare motor in case mine blows halfway through summer.. I want to rebuild the spare.. The extent of that depending on how much time the current gives me lol..
All parts are used
garret 60-1 journal bearing turbo, .63 ar no shaft play
Afi ramhorn manifold t3, 44mm v band wastegate
integra 2.5" intercooler piping
Precision intercooler 31x9x2.5
Xs bov.. Going to remove and use my greddy type rs bov
I have a 3" downpipe with big dent in it
Act hdss clutch/pp
Going to resurface my gsr flywheel
Aem uego wideband
Oil feed & return lines
Still need:
Wastegate
Walbro fuel pump
Injectors, possibly buying Bosch 1000s
Map sensor
Boost and water temp gauges
Boost controller?
Upgrade to 3" exhaust. Current is 2.36"
oil filter sandwich plate or oil pressure feed
Oil pan bung welded or pan w/ bung
All I can think of off the top of my head right now.. Thoughts? Will be on 91 octane
I'll be getting hasport mounts when I can afford
OEM valve seals
OEM head gasket
OEM timing belt
OEM water pump
ARP head studs
All parts are used
Act hdss clutch/pp
Aem uego wideband
Still need:
Wastegate
Walbro fuel pump
Map sensor
Boost controller?
My EG Hatch Build
http://civic-eg.com/viewtopic.php?t=22106
1993 Civic SI Hatch - project!
1999 Acura EL - winter beater!
