- Tue May 23, 2017 12:11 am
#6906892
Well to start I have a 1992 Honda Civic DX hatchback.just bought it last weekend it came with no water pump no timing belt and was missing quite a few things off the front of the engine. Guy sold it because it had a crack block around the water pump housing I grinded the crack out TIG weld everything very carefully grinded the tig welds all nice and move to a factory finish. Well in the process of installing a timing belt and water pump I realized it wasn't working. For some reason the timing belt was way too big. So I started looking stuff up and realized that my D15B7 has a mini me swap already it has a 97 D16y7 VTEC head. So I had to get water pump and belt tensioner pulley for the D15 and a timing belt for a d16y7 motor. After that the distributor was not working. so I looked and looked and could not find any distributor with the OBD one wires on it then found out I have to take all the stuff out of an OBD1 and put it in the OBD2 Daisy which I redid. After that it started right up. Sounds great has great compression on all cylinders all around 175 183.... It also has a p28 computer.
I came across a 92 Honda Civic from Japan. At junk yard It had what appeared to be the same engine that was in mine but wasn't VTEC and has a brand new head on it. I thought okay well not big deal I could just switch the head. But I'm very lost about this. Because the motor is a ZC MOTOR which everyone saying is the same as a D16. But has higher compression. And makes about 130 to 140 HP
Im lost guys please help can I use this block should I keep the block as it is. Is the new head going to compromised the original engines horsepower. The head is a PM3-18.
