- Tue Mar 08, 2016 4:40 pm
#358603
Hello guys i have been very inactive here for the last 2 years or so but im gonna make up for it now :thumbup:
I bought this Honda Civic EG6 shell one year ago and it was in a pretty bad shape to be honest.
the car had been dissembled before and was on its way to the trash but a buddy of mine bought the car and stored it in a warehouse for almost 2 years if im not lying.
So when i did pick up the car there was alot i needed todo everything for the undercarriage of the car was junk and from some other cars just to have the shell sitting og wheels. the wiring had been torn apart on many places and fuel lines and brake lines had also been taken apart so basicly i needed to wire up everything back and change everything for the undercarrigage.
i hope the pictures will tell the story better then my english
I Bought an B18c4 Engine and LSD transmission
Nýtt rafkerfi komið í og byrjað að raða aftur saman að innan
The first packets to arrive !
Mine is on the left and on the right is one for EK4 that my friend has
Stage 4 Clutch kit
Edelbrock
The motor going in
einn ánægður drengur með 17 ára bílinn sinn
Walbro 450L E85 fuel pump vs Orginal pump
Starting putting the turbo on
Intercooler pípurnar pössuðu ekki allveg haha
This hose there was a joke hope you can forgive me
The licence plates are on
ECU Mapping time using a chipped P28 ECU
We did get awsome power from the car but it lasted very short ! one street or so :eek:
So then i got angry and put the car inside the garage and did not touch it untill few days ago i started working again on it.
So i got another Engine 2 of them actually and more stuff on the way for it
Megasquirt 2 Standalone ECU
MSD Full setup
Zetronix wideband og digital boost ecu
and mostly everything i need for the engine.
Eagle h-beam rods
CP Pistons
Golden eagle blockgouard
ARP Head and main studs
OEM Type-R oil pump
OEM Waterpump
New headgasket
ACL Main, Rod and thrust bearings
And Gates timing belt kit
and when the engine is back in and running i will start working on the car it self brake upgrades and suspension upgrade maybe i will fix the body and paint it we will see.
Stage 4 Clutch kit
Edelbrock
The motor going in
MSD Full setup
Eagle h-beam rods
CP Pistons
OEM Type-R oil pump
OEM Waterpump
New headgasket
