- Thu Jul 19, 2007 1:19 pm
#15471
good stuff teal....when are you gonna install everything? what kind of numbers are you looking to get with ur setup?
Anything more than that is it's axle breaking & clutch slipping.
I'll probably call it a day @ 275 WHP. That should be scary enough
The only bottle neck in the setup is the internal wastegate. I'm not sure how many lbs of boost I can push before I get too much boost creep using an internal wastegate. I've got the internals to handle plenty of boost though
I'm going to get it tuned with this setup, and then down the road I'll get a better manifold & external wastegate and remove & weld the internal wastegate closed.
