By EG Bruce
#59283 can u swap the door panels out of a civic si into a cx and the required stuff to give u power windows in a cx hatch.
By Classiccarsrule85
#59288 I guess ill answer this yes you can as long as the stuff you got is from a 2/3dr car they will interchange but for future reference front the doors up to the front of the car everything is pretty much interchangable and the 3dr everything will swap over etc....
But also if you can only get the door panel stuff such as the pocket, control panel for the windows and wire harness door window reg of coarse but as in the door panel you can cut it open up some more in order to have them fit in most are already pre-outlined. (Did the door pocket swap in my cx from a si )
Also not to mention an Si at least most ive seen have had manual windows the only power windows ive seen are on Ex 2dr coupes .....
Hope this helps
By EG Bruce
#59292 yea it did help thanks, i guess off to a salvage yard it is lol.
