- Thu Apr 30, 2009 1:47 am
#114045
Suddenly driving lately, when im holding in on the clutch or about nearly pushing it into gear, it makes a hissing sound... anyclue on whats going on? also when i looked under today, a really black oil or fluid type is leaking off the flywheel cover... what can i do to stop it, it looks alot different then the motor oil , can it be brake fluid or power steering fluid...? this is a d16z6 thanks
Your rear main seal could be bad causing motor oil to leak and come out of the flywheel cover.
Could the hissing be a scraping sound? How many miles are on your clutch?
May be the release bearing since it does the sound when you are pushing the clutch pedal down.
