- Tue Apr 01, 2014 12:56 pm
#343922
Hello!
I'm having some problems with my s1 trans, I have the car up on jack stands and when I put the car in gear the axles dont move, it doesnt matter what gear i'm in, at first i thought it was clutch or pressure plate issues but I rulled that out because if I try to put it in gear without pressing the clutch pedal the gears grind. Another thing I noticed was if I move the axles with the car off and in gear I dont hear any movement in the trans, also since I have an open diff trans I'm pretty sure that if i move the wheels by hand in any direction the wheel on the other side should move in the opposite direction and this does not happen and when i do move the wheels with the car in gear there is no resistance it moves freely, I'm sure my diff is the cause. Has anybody else had a problem like this?
Thank you for your time!
