- Sun May 13, 2012 2:23 pm
#304779
Thanks guys for the info! I was going to post this yesterday. I read in another forum, all the different tricks to bleed any hydraulic system. There was a trick of using some clear tubing from the slave valve to the resivior, which was the one the I used and it work. Now my clutch feels right.
I will look for the link on this trick and post it. But is a simple use of clear tubing from the slave valve to the resivior. Make sure that the tubing is inside of the fluid to prevent air from entering the system. Pump away until there is no sign of air bubbles in the clear line. Make sure to keep the system full while pumping.
95 EX returning to life!!!
