-'93 coupe
- Wed Sep 08, 2010 9:40 am
#212743
You would not be able to turn the wheel, you need a way for the piston inside the rack to expel the fluid out of one chamber and into the other chamber again. If you plug the holes you get what's called a "fluid lock" the ideal way to run this is to install a cross union fitting where the 4 lines can be connected together without any restrictions.
jayEGR wrote:ok quick question can i close all the holes on the rack and pinion with bolts so no fluid will spill , or would that lead to locking up my rack and pinion and needing to replace it
(o0)\(III)(III)/(0o)
- Thu Sep 16, 2010 1:02 pm
#213977
yes
- Thu Oct 14, 2010 2:23 pm
#218323
smart idea
gonna try this when i take out my power stering
my build> blue bandit-sold=[
http://civic-eg.com/viewtopic.php?p=203107#203107
taco build!
http://civic-eg.com/viewtopic.php?t=17613
taco build!
- Fri Oct 15, 2010 12:51 am
#218399
stealthmodeperformance.com has a set-up for those wanting to remove their power steering.
- Thu Dec 16, 2010 2:06 am
#228174
what's the diff between the innner and outer tie rods from Manual to power?
Team XXX Racing/WGHonda
- Fri Nov 11, 2011 3:43 pm
#281082
why not just swap in a manual steering rack from an EG that came with manual steering? My PS rack is leaking somewhere, was planning to just swap in a manual one but all I can find is information on looping the hose.
My EG Hatch Build
http://civic-eg.com/viewtopic.php?t=22106
1993 Civic SI Hatch - project!
1999 Acura EL - winter beater!
- Sun Nov 13, 2011 1:26 am
#281232
This is the thread for you...if you can find a civic with a manual rack, try to get the subframe at the same time...and then rip out about 25 pounds of brackets and pumps and hoses! Apparently you don't need the subframe for the swap to work, but the power and manual subframes have different passenger side shock mount holes.
- Page 2 of 3
- 1
- 2
- 3
