- Thu Nov 15, 2012 8:28 pm
#320071
This all started when I switched wiring harnesses at first the speedometer didint work at all and no CEL then I unplugged everything to test to see if it was getting power and was connected and then It bounced a time or two and gave me a VSS CEL. Then I decided to check the thermostat ground and reset the ECU at the same time to clear the VSS code. I cleaned the ground point off good and put it back together hooked the battery up and took it for a test spin.
Here is what happened I have not checked to see if I have a VSS code again or not yet. Sorry about the shakeyness its hard to drive with no power steering small wheel and shift while holding a phone lol.
Honda Bad VSS? - YouTube
1995 Civic Hatchback CX D16z6 - Under Construction.
