- Thu Dec 15, 2011 3:06 am
#285466
Hello all,
I recently (past 2 weeks or so) started getting a Check Engine Light which only pops on after driving/idling for ~15 minutes. It goes away as soon as the ignition is turned off, and does not turn back on again until driving for another segment of ~15 minutes.
With the engine and ignition OFF, I shorted the ECU jumper with a paperclip, then turned the ignition to ON. I received two sets of codes - 17, and then 9. I know 17 is the VSS (which I replaced last year) and presumably this is still in the ECU memory as I have not cleared it (is that correct?). Code 9 is the CYP...
I recently replaced the distributor (http://civic-eg.com/viewtopic.php?p=280059) and I had some difficulties getting the timing set right (that is to say, I don't have a timing light and pretty much timed it by ear). I have NOT had any stuttering/loss of power/stalling/etc. However, I wonder if this could cause me to burn rich or piss gas away, because I've only gone 100 or so miles on this tank of gas and the gauge is reading half tank (and I usually hit 200 before "half tank", then the second half of the tank is 100 miles
Does it seem possible for my timing to throw this code, or could it be the CYP itself in the dizzy? The dizzy is "new" but as noted in the post I linked, it IS a OEM dizzy from Autozone.
Anything else that could cause this code, or that I could try troubleshooting wise? I've reviewed a few pages online, such as this one (http://honda-tech.com/showthread.php?t=2904710) but would like to get some expert opinions from EG :-)
Thank you!
Thank you!
