By dipdawg
#101280 I went to change my oil drain plug is spinning freely and wont come out. I thought about an extractor bit but idk if that would work since it would just spin.
By blockustomz
#101288 sounds like its really stripped out.. i would put wise grips on it and drill it out. then i would use a self tapper drain plug
By Classiccarsrule85
#101293 id just get a new oil pan from the yard and call it a day but yea really i think those are the only two options have you tried pulling while twisting maybe it might catch and get itself out there
By dipdawg
#101311 Yea i tried it but no luck. I guess ill just take the pan off and see if i cant get it out. Thanks alot guys.
By Sentry
#101320 When I drained the oil for the first time on this car I discovered the threads had been repaired with a helicoil. Some quicklube shithead must've zapped the plug in with an impact or somehing. :roll:
By dipdawg
#101325 Damn that sucks man. Are there any outher seals i can replace when i have the pan off.
By hondajunkee
#101494 What kind of pan do you need? I got a d pan sitting here in the garage I dont need
By dipdawg
#101800 Its a d 16z6
By hondajunkee
#101816 thats what mines off of, let me know if you need one, its not the nicest, but it works, and as I seem to be doing lately Ill sell it to you cheap
By dipdawg
#103068 I got the bolt out and retapped it if it doesnt hold up ill hit you up on that oil pan.
