By mregcivic
#90446 I'm desiding to buy this coupe from this guy n I dnt kno if I should cauz it needs an engine mount if I buy the car could jus pop open the open n install the new engine mount or does it involve pulln out the whole engine?????????????????????????????
Newb.....
#90484 you can just replace a mount. Support the tranny/engine & unbolt the mount & pull it out, then replace.
If it is the rear mount then you're in for a lot of work, it's a PITA to get to. If it is the driver side or pass side mount then it's a breeze.
#90485 There are five mounts. The two that are immediately obvious when you pop the hood are rarely a problem. There is no benefit to upgrading these two mounts.
The front lower mounts are almost always bad allowing the engine to rock excessively on hard throttle and shifting. One is on the AC engine mount (whether or not you have AC), and the one on the tranny. These two can be accessed from underneath the car. Support the engine with a jack on the transmission and remove the two bolts on each mount. Then remove the nut and slide the mount off the stud.
The rear mount is very difficult to access unless you have the car on a hoist and the intake manifold removed. This mount is critical not only to the engine rocking, but to the vibration transmitted to the chassis. If you are using aftermarket mounts or inserts on the other mounts, and this is a daily driver, then I suggest you use nothing stiffer than an OEM replacement rear engine mount. Otherwise your car will rattle like crazy when idling causing all kinds of annoying sounds in your interior.
By jaysuper
#100053 Plus I just replaced all mine and payed $100 you cant beat that. :lol:
