- Tue Apr 08, 2014 7:57 am
#344224
History: Bought the car (95 Honda Civic EX 1.6L) 5years ago with 180xxx and now has 222xxx miles
The car ran perfectly until 2 years ago when I bought a motorcycle, due to neglect (forgetting to check coolant levels) the car began to overheat due to no coolant in the radiator. Since then, I have been having on/off heating issues.
back to point: In the span of 2 years, the car has overheated about 10x. I have replaced 2 radiators (once was a leak on the bottom,second time cracked the top plastic off), hoses, 3 blown radiator caps, thermostat, fan, fan-switch, and coolant temp. sensor. Every time it overheated, I would take it to the shop and replace whatever part that got blown or ruptured;after doing so it would always fix the problem. Despite my efforts, usually 2 months after repairs, the overheating problem would persist. Today while driving on a congested highway, I noticed my temp. needle going above half-way. I turned on the the heater and the needle went back down to normal (little bit below half way). About 15min. later (Highway cleared up and was driving normal highway speeds 65mph) the car shut off. I pulled over to the right and waited for the engine to cool down. I then checked the radiator and still had coolant inside, checked oil and for leaks and no apparent signs of leakage. I got back in the car and tried to start it up but it did not want to start. I don't think its a blown head-gasket, since i have checked the oil and coolant and no white smoke coming out the tail. I'm going to try out the compression test and or replace water pump. I will keep you updated ..Any information will be appreciated. thank you in advance.
