- Thu Oct 02, 2008 1:35 pm
#72413
teal_dx wrote:give us some more info on your motor setup , how many miles, any mods? How often do you have to fill your coolant?
i own a 1994 civic ferio,running a D15B3 under the hood. in July 2006 i was driving in the high way when i realised that the temperature needle was reaching "H" level. Stopped the car immediately,and opened the hood. No smokes were detected,i opened the radiator cap,and water was missing. The water pump was tottaly ruined and the water was flowing from the pump.
i called my mechanic to come n pick me up,when we got civic at the garage (140000 kilometers on engine) we had to replace timing belts and water pump. I personally took the radiator to a guy speciallized in radiators-coolants-intercoolers-oil coolers, he "opened" it,sprayed it with high pressure hot water and then sealed it, put it on the board and carefully saw with a flash light if there were any cracks or holes on the radiator's body. Thank God they weren't at all!
When i got back to my mechanic, he told me "hey man, u r soooo lucky that there isn't a head gasket problem!"
New OEM hoses from Honda Dealer in my country, new thermostat, anti-freeze coolant, de-ionized water and start the motor for about 10 minutes so that thermostat can be OK.
after that i opened the ventilation pulley,and the spare air-water came off there. the civic was juuuuuust fine!!! Now i'm running 180000 on that engine (40000 more since 2006) and everything is OK. I change the oil every 2500 kilometers or less,and i check the radiator,the anti-freeze coolant, the hoses,everything!!! So that i won't have any problem in the future...
next stop: EK9 radiator! or aluminium 2" radiator...
That's from me guys...
