- Sun Feb 02, 2014 10:42 pm
#342101
Hey guys, my car's been acting up lately and I can't figure it out. It seems to happen when its a little more humid outside. It always starts up fine and idles correctly, but sometimes all power cuts out both under load and not under load. When I give it throttle while the power is cut out, it will bog down and not fire at all. If I let it idle a few seconds then it usually goes back to normal. I though it was a fuel issue so I have replaced the fuel pump, the fuel pump relay, fuel filter, and plugs/wires but that hasnt done anything. Should I be checking my distributor?
Thanks,
-Ben
Thanks,
-Ben
