- Sun Oct 14, 2012 12:45 am
#317894
1994 Ex 4 door 1.6 auto with A/C
So recently I have been having an overheating issue. I cannot determine where the coolant is going. No visible leaks under car, oil is ok so it is not leaking through head. I did a radiator system pressure check and a block exhaust gas check and both passed ok. I pressure checked at 16 psi for about 5 min and it never dropped. I cannot see any smoke of any color coming out the back of the exhaust so I don't think the coolant is going through there.
I have replaced the thermostat and the radiator cap. still over heats. Fans kick on and both hoses get hot.
Kind of lost and don't just want to replace radiator, and definatly don't want to just do a new head gasket.
The only clue I have is that I get a lot of air bubbles going into the overflow bottle.
any suggestions ides or tips welcome. thanks
