- Sun Sep 05, 2010 4:49 am
#212274
i am trying to figure out what i need to do to on checking my distributor timing with a timing light. i lost not sure where to start. please help
MG6 wrote:Question, is there a reason to check your timing? Is it running rough?
To do a timing check with the gun.
* connect it to power your gun
* hit the gun to your crankshaft pulley
* once you hit it, you will see marks as the gun with flash to visually make it visual to see your marking.
The marking will show you where it is in position to your TDC marking.
