By Weaksos
#158705 ok so i went to lunch from worl to get gas drove 5mins fine. then i pit 10 bucks of 87 from the circle k. as soon as i kit the street the car loss all power. i had to run the car at 3k to keep moving and running. the car seems to be flooding its self out at idle but if you can get it running and run it at 3 tp watever it will run blowing out white smoke then it will clear up smoke that is. but if you take ir down to idle spped it will just burp and miss and bucl then shut off. now our head tec said replace the exhaust manifold because it was crack and i may not be getting back pressure. well i have done that no change but a nice shinny header. talk to a friend of mine at honda said sounds like bad gas. also i dont have any check engine lights can anyone help me out thatnks car is a 95 ex coupe with a z6
By Weaksos
#158888 Problem solved bad gas also messed up 2 spark plugs. Drain it out then ran v power and stablizer. Long story short bump circle K!!!
By PandaHatch
#158905 i would go cuss the circle k out.
