By andyc
#205506 wel its not starting at all now :x
all is same as before and its definetely not the filter either. when i was checking the dizzy out, i can hear a faint high pitched whine from the rear of the bay, sort of from the driver side (were RHD over here). Ive never heard that before, anyone know what that could be?
By andyc
#205508 ive now noticed theres an earth on the transmission thats hanging on by threads. could this be the problem? I didnt know there were 2 earths?
what function does this earth perform? I mean is it the same as the rocker cover earth?
#205510 There's actually 3. Valve cover, transmission and thermostat.
All 3 are important, fix that and see. Even if it's not the cause of the problem, it's still fixing another problem in advance :thumb:
By ExCoupe94
#205512 the starter grounds (earths?) out on the motor if your motor doesnt have a sufficient electrical path back to the negative battery terminal wether it be through the chassis or through heavy gauge wire your starter wont kick. troubleshoot with jumpercables (create sufficient ground) and if it fixes your problem make a more permanent solution... amp wire + loom ftw!!!
By andyc
#205513 ok, its not the earths either.... what could the high ptche whine be at the back of the bay?? it has to be involved.. :headscratch:
By andyc
#205514 this is the thing ExCoupe94, the starter is turning over fast as ever just isnt firing up??
By andyc
#205527 ok, the whining is only after turning it over for a while... Ive taken out a plug and tested for spark and nothing. what could cause this??
By d-mon
#205636
ANDYC wrote: the starter is turning over fast as ever just isnt firing up??
is the starter gear engaging the flywheel?
By andyc
#205637 would that cause there to be no spark?
By Torch_Ind
#205676
chilango41 wrote:It would cause it not to start, thats for sure.
Double check the connections on your starter :thumb:
what he means is it turning over the engine!! is your belts and alt and stuff spinning when you engage the starter??
that or if it turns over fast and your alt belt is spinning everything it could be your timing belt is broke or has teeth missing.
By andyc
#205771 no buddy, as per the thread title its turning over....
is this re the cel right?
"If the CEL does not go out, most Civics will not spark and the fuel pump will not run. That's why we begin our diagnosis here."
By andyc
#206217 Ive now checked the ECL for codes and I havent seen one reading off for codes before.. can anyone make sense of this for me? I had to draw the line at 10 mins, I couldnt tell the difference in flashes, they all look the same to me??
http://www.youtube.com/watch?v=Y606F10WL0U
By MG6
#206235 never seen a long flash like that before. But i took this off from HT from pdiggitydogg posting that is a sticky.
-----CEL # List-----
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperature sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperature sensor
12 EGR - exhaust gas recirculation lift valve
13 BARO - atmospheric pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmission lockup control valve
20 Electrical load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmission A signal
31 Automatic transmission B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuation sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
By andyc
#206340 Thanks for that buddy, anyone else have any idea what this ecl is for? I dont understand it, ive never tried this before. I have a meet with some civic-eg guys and really dont want to miss it... :(
