- Fri Feb 14, 2014 4:31 am
#342623
on both of the sensors the wires have come off so no connection whatsoever,
i just finished checking the grounding and i finally wired it right so the fuel pump is working without the extra wire but its still not starting im having a crank no start issue. the engine is grounded properly on both the valve cover and tranny when i turn the key it just cranks, sounds like it wants to start but doesnt.
i did a spark test using the spark plugs and there was no spark that i could see
i did not disconnect the battery before messing with the wires so a messed up ecu could be a possibility, i replaced the main relay a couple months back so idk if that could be it.
i checked all of the fuses and replaced some that were blown. found out that a couple of my car features actually do work (heater, power mirrors, etc)
but i have a 92 civic si with a b18b swap, dc headers i think thats the only mod engine wise. i believe it has the obd1 harness some wires are completely cut off from the sensors such as the thermostat and coolant sensor, a Yellow/green wire is also cut off that belongs to the distributor
connecter, and 3 other wires are loose they are a Yellow/green , Green/yellow, and Blue/black
thanks for all your help teal i really appreciate it
