- Fri May 01, 2009 5:26 am
#114280
my Old Coupe with a D16z6 with I/h/E would smoke B20 swaps all the time. B20's are slow.
The B20 will need a b18b, b18c or B16 Transmission to bolt to, Integra mounts, shift linkage, etc to swap in. It will be alot more work for a slower engine. However It can take a b16 or B18c DOHC Vtec head and go B20vtec and they it will be pretty quick. However you will have to make the bottom end stronger. Even then for the money you spend on your B20vtec the JDM D15b will still smoke you.
If you couldn't tell I highly recommend the JDM D15b, Get the LSD Tranny with it. basic I/H/E and you will beat up on B20 and B18a/b swaps. A little nitrous and you will be beating up LSvtecs and B20vtecs and B16 swaps.
I Speak from Experience. I had a D16z6 with a bottle that took everyone down.
