- Wed Dec 02, 2015 8:28 pm
#357745
Hiya guys so I read the sticky on not starting, rather ask your opinions please, ok so came out one day and she wouldn't start was fine up untill then, it cranks, has a spark from the coil and a better one since I swapped the coil, but no spark at the plugs I tested with a spark tester, swapped for oem dizzy cap, New rotor, no codes from ecu, fuel pump priming and pushing fuel from the nut on top of the filter banged the tank too, main relay tested fine no solder cracks, grounds all good terminals ok battery is fine, it has factory immobilizer and alarm have been told this cuts starter signal which I am getting at the main relay when de immobilized, any ideas much appreciated please
![BangHead [smilie=BangHead.gif]](./images/smilies/BangHead.gif)
