- Fri Feb 15, 2013 6:25 pm
#326519
Running w/o a thermostat, manually wiring up the fan are both lazy fixes which do not fix the original problem, but instead cover the true problem up while it gets worse. Eventually the problem will get so bad that no thermostat and constant fan running will not keep the car cool.
I'd do a compression test to be sure, but everything points to a leaking headgasket. Look for cookie dough under the radiator cap and coolant in the oil.
