- Tue Aug 05, 2014 7:00 pm
#347689
The car is basically stock setup with a few changes:
Front lower control arm bushings and radius arm bushings have been replaced with Prothane polyurethane bushings. Stock arms.
Struts/springs are Monroe quick strut assemblies, stock ride height, only $400 for the set. I had lo-tech quick strut assemblies but replaced them when I bought the car because they were too low and way too harsh.
Front upper control arms currently are adjustable, unknown brand, orange colored with slotted openings for the ball joint bolts so camber can be adjusted in or out. The thin edge along one of the adjuster slots is broken, so I want to replace the arms with something that has a solid frame around the slotted slide tracks, such as these:
I would like poly or hardened rubber bushings preloaded in the upper arm brackets, as well as a ball joint that will last a long time. Any recommendations based on experience appreciated!
