- Fri Apr 11, 2008 2:39 pm
#50078
1. SlipCivic 1995 Honda Civic ESI
2.
stefan 1995 Honda Civic LSi
3. EG-nath 1994 Honda Civic
ohh and a couple pics from my recent head rebuild
[/quote]
4. Jdm_Katie Honda Civic ex coupe
Car is pretty much standard and rust free still with original Honda shell and no new replacement panels.
Some subtle modifications as follows:
Engine:
Standard d16z6 VTEC and Gearbox
AEM V2 RAM Air Intake System
Iridium Spark Plugs
NGK Performance Ignition Leads
Interior:
Black UK Interior
Standard Honda Steering Wheel (With air bag, urgh!)
Standard ESI Seats
Stripped Rear Interior (Seats)
JDM RHD Dual DIN Centre Console 190209900174
Standard Gear Knob
Exterior:
JDM Amber Corners
Phillips Ultra Snow White Headlight Bulbs
Colour Coded Door Mirrors and Door Handles
Exhaust:
Spoon Sports N1 Exhaust System
Suspension:
Eibach Lowering Springs (40mm Drop)
Wheels and Tyres:
Standard Steel Wheels (As Slipstreams got badly damaged)
Mods comming/ or not shown in pics:
Momo Corse Steering Wheel
Recaro Red ITR Seats (In the mail but need rails )
Soon to be fitted with Skunk2 LCA's
Soon to be fitted with AEM Fuel Rail
Soon to be fitted CF bonnet and boot lid (JDM square plate housing)
Soon to be fitted CF Spoon Duck Bill
Soon to be fitted Spoon door mirrors
Soon to be fitted Window Tint
Soon to be Turbo'd ... eventually.
2.
November 2004 I bought myself a 1995 Civic coupe LSi with the D15b7 engine, manual.
Earlier cars have been an Escort, 2 Civics ED7 (D16z2), 2 Toyota Starlets, and a 89' CRX ED9 (D16z5).
CAR INFORMATION:
Honda Civic coupe LSi
1995
R81 red
UNDER THE HOOD:
- B16A2
- Exedy organic clutch set
- milled stock steel flywheel (5,8kg, or for you imperial guys; 17,6 lbs)
- solid engine mounts
- NGK spark plug wires
- fuelrail and stock fpr painted flat black
- OBX 4-2-1 ss header, black
- eBay resonated ss decat
- SRS ss resonated 2.38" inner diameter midpipe
- eBay twinloop Mugenstyle ss backbox, muffler painted flat black
- short ram on black alu pipe
- Coolchamber airbox + Green silicon pipe to an airscoop in the front bumper
- Mishimoto half-size EG6 radiator
- Mishimoto 16lb/f (1.1bar) radiatorcap
- twin oilcatchcan setup with Tenzo filters and 9mm tubes
- valvecover and spark plug cover painted black
- stock ground cables replaced by bigger audio cables
- Skunk2 triple ring camseal
- Skunk2 VTEC solenoid cover
- painted all brackets flat black, for a stunning 15 extra hp ;)
INTERIOR & I.C.E.:
- alu shortshifter
- Password:JDM shiftboot
- new OEM floor mats
- ProSport peak/hold gauges on dashboard; boost/vacuum, oiltemperature, oilpressure
- hand- and doorgrips painted metallic black
- factory a/c equipped (installation removed)
- MOMO Race steering wheel, Simoni Racing hub
- dashboard; needles painted orange/red
- single DIN audio console
- autostyle pedalcovers
- autostyle reclining seats (Bride knock-off)
- SCHROTH 2" ASM Autocontrol three point harnass
- replaced rear seats with a MDF construction
- eBay alu C-pillar bar
- OEM Honda Civic 2/4dr USDM 3rd brake light
- Pioneer DEH-4700MP head unit
- 6×9" JBL GTO rear speakers
- JBL GTO-4000 amplifier
- JBL CS series 12" subwoofer roll
- Pioneer two way front speakers
- battery placed in the trunk
- MDF construction in the trunk to hide the battery and accomodate the audio
- dual tone claxon 112dB
- electric power antenna, (trash, "if these things were people, I would embrace their genocide")
EXTERIOR & CHASSIS:
- summer; 15x7 ET40 Speedline Safari, no tyres atm due to restoration
- winter; 15x6 ET45 Civic 7th gen steelies, Dunlop SP9000 front, Bridgestone Potenza RE720 rear
- Muteki closed-end lugnuts, black
- Apex Racing full coil overs, lowered by approximately 80mm (3.25")
- Civic 4th gen mkI (1988) rear LCA's to accommodate eye connection type shocks
- MB6 282mm rotors and calipers up front (redrilled to 4x100)
- EE9 rotors and calipers rear
- EG6 master brake cylinder
- EG6 brake distributor
- EG9 Goodridge steel braided brake lines
- EG6 OEM tiebar front
- EG6 OEM 18mm swaybar rear (in stead of; no one at all)
- EG6 OEM 21mm swaybar front with PU endlinks (iso; 18 or 19mm)
- Ferrodo DS2500 brake pads front and rear
- NH503-P black trunk
- OEM EG8 mud flaps front and rear
- eBay front strutbar
- clear blackhousing head lights, made these power adjustable with OEM motors
- amber corners
- OEM USDM Honda Civic coupe taillights
- VIS Racing c/f hood
- Aerocatch hoodpins
[/quote]
D16z6 motor
AEM Short Ram Intake
Omni Coil overs
Blox Front and Rear Camber Kit
WedsSport TC-005 Rims
Yokohama Parada Spec 2 tires 205-45s
Blox Lower Control Arms
Vision Smoked Amber Corners
OEM Front Lip
Antenna Block Off
