- Fri Jan 23, 2015 3:34 pm
#351262
1. jred
2. egsedanguy 92 Hatch
3. Bobec
Car:
1993 Sedan EG9 SiR
Engine Type:
B16a
Drivetrain:
Y21 ( non LSD )
no name lightened Flywheel, ACT 6 puk clutch disc and Heavy duty pressure plate
Engine Performance Modifications:
Head work
Port and polish, 3 angle valve job
Brian crower valve springs and retainers, titanium valves
Brian crower stage 2 camshafts
AEM adjustable cam gears
Gates timing belt (blue)
RC 370cc injectors
Walbro 255 intank pump
Skunk2 lost motion assembly (spring type)
Block work
Typr R replacement pistons & rings (oversized, 11.5 comp)
Block guard
ARP studs
Melling Aluminum high performance oil pump
Balanced crank
Clevite bearings
Bolt on's
Randy Monroe (RMF) Narrow Header, pipe 2.5" Exhaust .
AEBS Intake Manifold (polished)
Skunk2 Throttle Body 68mm
Short ram intake (home made), K&N Intake filter.
High volume fuel rail, Adjustable Fuel Pressure Regulator
Aluminum radiator
Electrical wizardry
MSD wires, distributor, and Blaster Coil, NGK platinum plugs.
AEM Ugeo wideband sensor/gauge
HONDATA S300
Suspension:
OEM front strut tower bar,
No brand rear upper strut tower bars
OEM SiR sway bar Front
Whiteline Flatout 22mm sway bar Rear
ASR subframe brace
Beaks lower tie bar
BC Racing BR series Full Coilovers
Energy Suspension polyurethane bushings all round
Driveshaft shop stage 2 axles
Brake:
Front; Wilwood 12.2" Big brake kit (dynalite)
Rear; OEM EG9 Brakes
Steel braided lines
Wilwood pads
Wheels and Tires:
16" Volk ce28 (replica), Dunlop Direzza DZ101 205/45R16 Tires
Exterior :
Factory Grenada Black Metalic
Replica Type R Bumper lip ( Front )
EK4 Side skirts (not installed as yet)
Black Housing Headlights, Amber Corners, Amber Sidemarkers
Interior :
DC2 Recaro (Black) seats up front
OEM EG9 rear Bucket Seats
OEM ITR Steering Wheel 96 Spec MOMO [Non-Airbag]
OEM ITR Titanium Shift Knob
OEM EG9 Long Armrest
OEM EG9 SiR Black Interior & Door Panels
OEM Foldable & Heated Side Mirrors
http://civic-eg.com/viewtopic.php?t=213 ... c&start=45
3. Bobec
Car:
1995 Coupe ej1
Engine:
Stock b18c4
Transmission:
S9B 4.26 final drive TORSEN LSD
Exhaust:
SRS Catback System ss R60
Suspension:
Koni yellow shoks front/rear
933 Motorsport front 3-point upper strutbar
SK-Import front lower H-Brace
933 Motorsport rear 4-point upper strutbar
SK-Import Rear Subframe Brace
Skunk2 rear lower control arms
98 spec Integra dc2 front 24mm and rear 22mm swaybars
Energy Suspension Bushings Complete Master Kit
Brakes:
Front - 282mm rover brake disks, with edm `99 Prelude 2,2 vti calipers
Rear - Tenzo-r 282mm big brake kit, with oem calipers
Goodridge Steel braided Front + Rear Brake lines
98 spec Integra dc2 master silinder(not on the pics, but installed)
Wheels and Tires:
15/6,5 BBS, Kumho Ecsta SPT 195/50/15
15/7 noname wheels, with toyo r888 205/50/15 (for track days)
Exterior :
Horizon Gray Metallic Clearcoat, RP-21M
OEM front Bumper lip
EK Side skirts
Aerodynamics carbon bonnet and trunk(not installed yet)
DEPO Black Housing Headlights(not on the pics, but installed) Amber Corners,
DEPO JDM Tail Lights
Interior :
Aerodynamics adjustable racing seat - driver(not on the pics, but installed)
OEM EJ1 leather interior
