Ride of the month nominations & voting.
#289324 How it works:
- This is a submission/nomination thread where members' vehicles should be posted.
- Members can post their own vehicles, or other members' vehicles.
- The owner of any car nominated must have at least 100+ posts and have been a Civic-EG.com member for at least 3 months.
- Post 4-5 pictures as well as modifications list.
- After 5 cars are submitted, the submission thread will then be locked and a New Voting thread will be created with all the vehicles. Then you all get to choose the Ride of the Month!
- The winner will have their car featured on the main forum page for the month. Also they will have their car added to the Civic-EG.com Hall of Fame.
- You can win multiple times as you continue to modify your car, but not more than one time in the last 12 months. See the Hall of Fame for past winners.
Let's see some submissions for February Ride of the Month! :woot:
By Ecc0
#289356 Think it's about time I try out for this.
Here's my spec list
Honda Civic EJ2 (EG) Coupe
B16A2 Engine Conversion
Wire Tucked Engine Bay
Shaved and seam welded Engine Bay
Custom Hel Brake lines
Custom Hel clutch line
Custom Hel fuel line with earls inline fuel filter
Benen Industies composite fuel rail
Ally rad
Password JDM rad stay
Password JDM cam seal
Hyper Flex Poly torque and rear engine mounts
VTI Sub Frame
DC Sports 4-1 manifold
SRS De-Cat Pipe
Apexi N1 Exhaust System
Carbon Fiber CAI with AEM High Flow Air Filter
FP Racing Short Shifter
VTI Front Calipors
VTI Rear Disk Brakes
Brembo Disks Front and Rear
SRS Front upper Camber Correction
D2 Coilovers (32 way adjustable)
D2 LCA's
D2 Rear Camber Correction
Complete Poly Bush set inc trailing arms
Summit Front upper Strut Brace
Summit Rear Upper Strut Brace
Civic VTI Front ARB
Civic VTI Rear ARB
Prelude Seats
5Zigen Steering wheel
Password JDM shifter knob
Password JDM ally battery with Odyssey Dry Cell Battery
Amber corner lights
EK coupe side skirts
USDM rear licence plate holder
Sunroof visor
Door window visors
Rear window visor (on route)
Datum 1 purple tow hook
Purple dress up washers in engine bay
By dbrooks
#290324 I want to nominate this guy :thumb:
http://civic-eg.com/viewtopic.php?t=20607
EJ1_MK
Mod List
Engine:
D16Z6
Header
Intake
Solid Mounts
Fuel pressure regulator
No A/C
No Power steering
2.5" exhaust no cat
Interior:
Momo Mod 8 steering wheel
Skunk2 shift knob off my EJ8
PasswordJDM Carbon Fiber Airbag Tray
All srs or airbag wiring removed including airbags
All sound debiting removed
Wink 5 panel mirror
C-Piller Bar
Exterior:
PasswordJDM Tow Hooks Black
OEM Honda antena Block off Plate
OEM Honda front license plate fills factory color
Rain Visors
Depo JDM Amber Corners
Brakes:
PasswordJDM Drilled and Slotted rotors front and rear
Hawk HP Plus brake pads all around
Goodridge Stainless Steel Brake lines
Rear disk conversion with new calipers and brackets
4040 Prop valve
Suspension:
Skunk2 Pro-C Coil-overs
Skunk2 Pro Front Camber Kit
Skunk2 Pro Rear Camber Kit
Skunk2 Rear Lower Control Arms Black
ASR Subframe Brace Black with 24mm Sway Bar
PasswordJDM 3 Point Strut Bar Front
PasswordJDM 2 Point Strut Bar Rear
PasswordJDM Trunk Bar
Hardrace Rear Trailing Arm Bushings
Hardrace Rear Toe Arms
Hardrace Compliance Bushings
Hardrace Extend Ball Joints or Center Roll Adjusters
Hardrace Outer Tie Rod Ends
Energy Suspension Front Lower Control Arm Bushings
Energy Suspension Front Sway Bar Bushings 21mm
Energy Suspension Front Sway Bar End Links
Energy Suspension Steering Rack Bushings
ARP Extended Wheel Studs
Buddy Club Racing Lug nuts Open
Wheels:
Winter 99 Miata wheels with Blizaks
Summer Konig Helium 15x6.5 with Yokohama S.Drive 205/50R15
Image[/url]
