- Tue May 17, 2011 4:21 pm
#255597
1. ceelx
2. 94EJ2
3. jayEGR
FUTURE PLANS
maybe H22A JDM /F20B JDM/F20C1 RWD EJ1
4. EG6b20R
1993 Civic Si.
Engine:
d15b2 refresh + minime
head from z6 refresh
engine oil -- now castrol 15w40 --> will be motul 6100 synergie 10w40
new rod bearing
piston from d13 engine with new ring
all new gasckets and seals
wirring harnes 10,2mm
wirring harnes separators VMW
NGK iridium spark plugs
valve cover, batteri tie down, radiator handle in green shine color
Plans:
adjust cam gear vision
camshaft stage 2
Intake system:
intake manifold from z6
intake big tube
filter K&N
intake filter k&n cover
Plans:
throtthle 60mm
Exaust system:
exaust header stainles 4-2-1
Plans:
cat conventer
twin loop jdm dual canister
Elektronics:
end of rmp 8200rmp
vtec 5200rmp
program from crome
maps by proturbo
Plans:
maybe start prcedure
shift light
vtec light
vtec controler
Uklad napedowy:
lights flywheel -- 4,86kg
new clutch
oem MTF
Plans:
Suspension:
front&rear up tie bar DNAmotoring
wheels -- in summer -- 6,5x15 proline pv, tire rear -- nexen n2000, front -- dunlop sp sport01 w rozm. 195/50r15 84V
winter -- 6,5x15 oem honda, tire dunlop sp winterresponse 185/60r15
eibach pro kit
kayaba agx
front&rear tie bar DNAmotoring in green shine color
Plans:
Energy suspension hyper flex kit
b-pilar
Breake system:
front swap to 262mm
rear brake convertion from eg5
breake disc brembo max + breake pads bosch
wire harnes stainless break
breake fluid bosch DOT 5,1
Plans:
big pomp & servo breake
Body kit:
colorcar -- ocher beige met.
front & rear lip type-r
jdm power folding mirror
headlight's clear black
corner amber usdm
oem tail lights usdm
jdm flat side marker
spojler ferio
license plate usdm
hood dumper
jdm visor
Mugen oil cup
Mugen fuel cup
30 washers on board
strickers
Plans:
jdm projector fog light yellow
bronze glass
3rd breake light ferio
sport resevoir tank cover spoon
radiator cup spoon
thin side door molding
Interior:
stock
rings onguages
replika guage SiR
Plans:
all interior from FERIO
JDM cup-holder
indiglo lights on heateng panel
short shifer & cover bot mugen or spoon
Car audio:
something ;)
horsepower in stock = 90KM
after mods + 128,4 KM 6615 obr/min i 145,9 NM 5411 obr/min
2. 94EJ2
current spec/mod list
engine/bay/drivetrain
D15Z1
cx trans
B&M short throw shifter
password jdm gold radiator stay
wire tuck
ballet slipper pink bay
rising sun under side of hood
injector plug tuck
exhaust
4-2-1 header
full 2 1/4 exhaust no cat
thrush turbo muffler
suspension
ground control coil over sleeves
drop zone struts
GSR brake conversion
exterior
15" konig lightning rims
ex trunk lid with spoiler
ebay mugen style lip
red clear tails
vision amber corner
3k hids
jdm syle fogs
interior
painted upper interior plastics
black recovered headliner
recovered rear deck cover
wink mirror
ex cluster with amber led's
usdm armrest
3. jayEGR
current
ENGINE/DRIVE TRAIN/UNDER THE HOOD
B20BJDM
b16tranny
stage 3 six puck clutch ACT
Findanza flywheel 7.5 lbs
innovative rear mount
oem honda tranny fluid
obd1 same wirin harness no splicing
D-series Alternator
LS intake mani
B20B JDM throttle body
NGK spark plugs
EBAY intake airfliter
EXHAUST
after market headers (ebay brand)
test pipe (ebay brand)
catback to muffler stock
SUSPENSION
skunk 2 full coilover and strut and springs
EXTERIOR
Track lite rims
benein tow hook
jdm blk housing head lights
jdm fog lights yellow
HIDS 8K
amber corners
type R lip
toyo tires in the front
falkens tires in the back
si rear disc
INTERIOR
cut of short shifter from an LS
skunk 2 shift knob
keenwood speaker all four
sony head unit
stock tweeters
usdm armrest
BRKAES
drilled and sloted rotors
cermaic pads durlast
golds durlast rear pads
FUTURE PLANS
4. EG6b20R
1993 Civic Si.
ENGINE:
1994 D16z6
Innovative 75A motor Mounts
Paint Wrinkle RED Valve cover
Skunk2 Intake manifold Bored to 68mm
OmniPower 68mm TB
Hondata S300
Ebay intake Pipe
BLOX Velocity Stack With Filter
Apexi WS2 Noir full Catback
Ebay High Flow Cat
NEUKIN Radiator and Slimfan
TUNED to 128whp/113 TQ
DRIVETRAIN:
Synchrotech S20 Reman unit 92-95 Si/Ex
Synchrotech LSD
Synchrotech Carbon Synchros
XTD Stage3 Clutch kit
Fidanza 8lbs Flywheel
OmniPower Quik Clutch master Cylinder
Russell Stainless Braided Clutch line From CMC to Slave Cylinder
SUSPENSION:
Ksport Kontrol Pro Coilover kit 12k front/10k rear
HardRace front Lower control arms
Hard Race front Compliance Bushings
Skunk2 Pro+ front camber kit
Front SIR-G Strut tower bar.
Rear BWR LCAs
BWR Subframe Brace
M2 Hardned Rear Traikling Arms bushings
ROKU Rear Strut Tower Bar
Roku Rear C Pillar bar
OEm 21MM Front Sway bar. Energy Suspension End links
WHEELS:
OEM 14' HX Wheels Painted in ITR GunMetal( Graphite) Style. I call them my Baby ITR wheels.
INTERIOR:
EDM Cluster 140MPH with Amber LED bulbs
DC integra front seats
OEm EG rear seats
NRG quick Release kit with LOCK
Ebay Black with red Stitch Wheel and Red H horn button
Spoon Shift knob
BLOX dual bend Short Shift
Energy Suspension Shifter Bushings
EXTERIOR:
Vision Amber Corner lens
10k HID Kit BiXenon
Rest is all Stock for now.
