- Mon Jul 23, 2007 12:08 pm
#16367
so my headlights have the usual cloud stuff on them and they look all foggy and shyt so i decide to fix that and while i had the headlights out i decided to paint them.
this is how they were b4.....this one wasnt too bad compared to the other side the other one was probably worse. anyways i started off with 1500 grit sand paper. while sanding make sure ur headlights and sandpaper are wet at all time if not the sand paper will scratch the lens. so i wetsanded them for about 20 min with the 1500 grit sand paper. then after that i wetsanded them again with 2000 grit sandpaper for about 20 min. after that i used some stuff called Plastic X its just like a plastic polisher but it does work pretty good. i just used a strip of cloth and polished it for a bout 10 min. after all that this is how they came out when i was done polishing them
then after i did that i took out the housing and painted it black
then the next day my friend at autozone gave me this color which he thought was the closetst to the typr r headlights so i had nothing to do so i painted them again with graphite grey
installed:
installed:
