By yashep
#52893 usually the tire says the correct pressure you should use
#52897 a lot of tires will say the max pressure on the sidewall, which is too much for driving. I would go around 32 psi and see how it rides & watch your tire wear. That should be a good pressure for street driving
By Graham
#52900 Front is meant to be a tad higher pressure than the back since there's more weight at the front, but its really up to yourself
I normally have mine between 30 and 35
By LowTEC-Derbo
#52904 i rock 32 in the front and 36 in the rear. gives the rear a little more swing to help rotate those corners.
during daily driving, its 36 all around.
#52906 I rock 32(cold) all around, but my tires are max 36psi
By thedaemon
#55973 I rock about 40psi for better gas mileage and less sidewall flex. It's a bit stiffer ride, but I don't mind.
