#40927 I just Painted up my Old rims and they look awesome.
- Newly Painted Rims on Car
- Detail shot on Rims
- Progress shot of Rims with only the Lip Painted. Showing how bad wheels where.
My Wheels have been looking bad for a while. Thats gets hidden to a degree when a photo is taken. I finally decided I will work on my Rims on my next day off. I bought 2 colors of Paint, Metallic Silver, and Metallic Dark Grey/Black. I also bought alot of Masking tape and Clear Coat for $27 USD.
Once done the Rims look beautiful. I am totally 100% Satisfied with how they came out. Its just awesome. Well what do you guys thing?
#40928 They do look a lot better :thumb:
By BAXTER_EJ1
#40954 How much did you sand? I'm planning on doing the same thing I'm just not sure how much I should prep the surface :thumb:
By Graham
#40961
BAXTER_EJ1 wrote:How much did you sand? I'm planning on doing the same thing I'm just not sure how much I should prep the surface :thumb:
Depends on how corroded/ damaged your wheels are
By BAXTER_EJ1
#40966 My wheels are basically just scratched, the red lip has some paint chips and there's just a little curb rash.
I think I'll just use some paint stripper, then sand with a few low grits and move my way up until I remove most of the scratches from the sandpaper, similar to as if I was going to polish them, but I assume I wouldn't have to go QUITE as far with the fine sandpaper because I'm going to be painting over them?
By Graham
#40973 You need to sand enough to get rid of any marks on the wheels, but you dont want the surface to be too smooth at that stage otherwise the primer might not stick to the alloy, but equally you dont want but gouges out your wheel :lol:
teal_dx wrote:what brand paint did you use?
Duplicolor Texture Metalic Coating. - Webpage
1 can of the lightest color, 1 of the darkest. the Darkest can is now empty after all 4 rims :lol:
BAXTER_EJ1 wrote:How much did you sand? I'm planning on doing the same thing I'm just not sure how much I should prep the surface thumb up
I sanding most of to corroded areas down smooth. then used a medium grit piece of sandpaper and got all the areas of the Rim I could so the paint would have somewhere to stick.
When I was done I put 2 layers of Generic Automotive Clearcoat on the Rims. Hopefully helping to protect the new paint from the elements.
By BAXTER_EJ1
#41004 Thanks, that info will help a lot.
#41006 They do look good! Good work man!
#41045 what is an 8" quantem tek rim?
They do look better.
Greasedmonkey wrote:what is an 8" quantem tek rim?
It is an 15"x8" Rim Meaning 15" Tall, 8" Wide Should have explained that better. Made by Quantem Tek. They are Made in Korea. Manufactured in 2000. At least thats what the Wheel Casting says.
I have been looking to get anouther set of 15"x8" Rims but have not had any luck.
York62 wrote:They do look good! Good work man!
:thumb: Thanks!
#41375 damn, those things are 15x8? what size tire you running on those?
Greasedmonkey wrote:damn, those things are 15x8? what size tire you running on those?
195/50R15
They stretch just a little, but nothing major or noticeable. :lol:
By BAXTER_EJ1
#42062 The website says no primer is needed, but I know that primer never hurts...
Did you use it or not? :thumb: I have my rims off and cleaned, so I'm hoping to get to the paint in the next few days!
