- Sun Nov 06, 2011 2:02 am
#280352
If you do a mild drop say 2" or less, and go with a wheel/tire that isn't too aggressive, you'll be OK. Yeah you'll have a little more negative camber than you did before. But it won't be anything crazy like the stanced out cars have. Just get an alignment after lowering so that the toe can be corrected and you'll be fine. It is toe-out that chews up tires fast.
For the wheels, 14 or 15 is ideal. 16 or bigger increases your chance of rubbing.
So lets go with 15" as an example because that's the most common size.
Don't go any wider than 15x7. Most aftermarket wheels come in 15x6.5 or 15x7. This is a safe width to avoid rubbing. Another important measurement is offset. Keep the offset of the wheels somewhere between +35 and +45 and you won't need to roll your fender.
That's how to lower your car and keep it practical. If you wanted to slam it and do the rolling & camber kits, then that's another story.
