- Mon Jul 20, 2009 11:15 pm
#131904
Good evening from sunny England
Found a link to this thread on a civic forum I use, and I've gotta say it's one of the best write up's I've ever seen! I'm currently in the process of rubbing down my EM1 wheels (think you guys call them Si alloys in the US) and have just finished 1000 grit on all four wheels. They were fairly corroded around the centre of the wheel and unfortunately I haven't been able to get through all the corrosion, even after starting with 240 grit. It has left a faint mark where the corrosion once was.
I will now be masking the face of the wheels up, ready for painting inside the spokes. This is where I need some advice. I notice that you have used a spray called Duplicolor, unfortunately we don't get this item in the UK. Instead of using this, would I have to use a metal primer (presumably grey), followed by the graphite/gunmetal colour, and then clear coat lacquer? Does the paint even need to be lacquered, as surely this will crack and peel once I continue rubbing with wet and dry?
Any help would be greatly appreciated!
Aaron
