- Thu Apr 07, 2011 5:45 am
#248846
So I just got stoned and started thinking about CCWs again. Then I started looking around on the internet and saw what people were doing with their Hondas on the CCW website. I pulled up a wheel calculator and started brainstorming. This is what I thought of, and nobody else seems to have it.
My EG is aztec green pearl (which I feel works perfectly with gold).
The CCW LM20
http://www.ccwheel.com/wheelprofiles-di ... hp?id=LM20
But I would want it with the gold anodized center with a polished lip.
Dream wheel size: 16x8 all around (5 lug conversion required)
2.5" lip
+19mm offset
225/45 tires
Calculator results as compared to a stock wheel. First number is stock wheel, second number is dream wheel. Stock wheel size (I think) is a 185/60R on a 15x5
Diameter 577.6mm 608.9mm
Circumference 1814.6mm 1912.9mm
Poke 18.5mm 82.6mm
Inset 108.5mm 120.6mm
Speedo error 0% -5.14%
Reading at 30mph 30mph 28.46mph
Reading at 60mph 60mph 56.92mph
Ride height gain 0mm 15.65mm
Arch gap loss 0mm 15.65mm
http://www.willtheyfit.com/index.php?wi ... mit=Submit
With lots of coilover and camber adjustment trial and error I think this setup can fit an eg. I currently run a 205/50R 15 on my civic. I like having a some meat on the bone. That's why I picked a 225/45 for a 16x8.
On a side note; I don't know if anything I just typed makes sense. I don't even think I properly used that semicolon. If these tires won't even fit and I am making no sense please correct me.[/img]
The CCW LM20
2.5" lip
+19mm offset
225/45 tires
Poke 18.5mm 82.6mm
Build thread:
http://civic-eg.com/viewtopic.php?t=21878
