By JDMZC
#120787 will this specs fit an eg hatchback?
Pattern: 4x100
Offset: +35mm
Hub Bore: 67.1mm
195/50/R15
currently rolling on
Pattern: 4x100
Offset: +40mm
Hub Bore: 67.1mm
195/50/R15
my car sits 1/2 finger gap in front and 2 finger gap at the back....
i know that the wheels will extend 5mm more....but has anyone actually tried it? any pix?
thanks a lot!
#120796 It'll work! I've seen 16x8 +20 on a hatch 8)
By JDMZC
#120992 you mean it will work without rolling the fenders???
Thanks guys....
#121046 it all depends on your drop, but if it were to rub, I think it would rub in the front since it is lower. the front fender is like thick tin foil, you can push the inner lip up with your bare hands if it rubs.
