- Wed Jul 14, 2010 7:36 pm
#204631
Just imagine going from 180 grit sad paper to 2000 in 4 wheels. Put some steelies on
teal_dx wrote:GSR's would be easy because they are more flat and only 5 spokes. Lip is a simple design compared to HX's too.
You want sand paper for wet sanding, the grey stuff.
Use a sanding block for flat surfaces because using your hands can cause you to round down the edges of the spokes. Bur for getting in tight areas or curves like on rims with a stepped lip, fingers work best.
For the fat 5's I would only polish the surface and paint the inset areas on the sides of the spokes. they are usually a rougher casting and would take forever to smooth.
