- Fri Apr 01, 2011 11:58 pm
#247669
yea, follow what Teal wrote up, but I copied and pasted.
"So if you notice any of the symptoms mentioned above, check for wheel play.
With the car on jack stands, grab the left and right sides of the tire and wiggle it as if you were trying to shimmy it off of the hub. If there's play, then you need to replace the inner and/or outer tie rod. (play from top to bottom is usually a ball joint - check upper and lower control arms. Play in all directions could be a very worn wheel bearing - you would hear this while driving) "
