ECU, Wiring, Sensors
By Classiccarsrule85
#104193 did you check the plugs on the fuse box i know in that harness there are 2 plugs going to the fuse box....besides that is your cluster n all that working? thats all one semi easy to remove harness not sure if its the harness tho....
By ballistic
#104232
Classiccarsrule85 wrote:did you check the plugs on the fuse box i know in that harness there are 2 plugs going to the fuse box....besides that is your cluster n all that working? thats all one semi easy to remove harness not sure if its the harness tho....
I checked the plugs on the fuse box and they do have power, yes my cluster and the rest of the interior lights are working besides the clock and radio.
Thanks.
By dawg316
#104258 check underhood fused labeled ECU backup or something like that. my friend had a similar problem and that fixed it
#104263
dawg316 wrote:check underhood fused labeled ECU backup or something like that. my friend had a similar problem and that fixed it
:thumb: :thumb:
They're on the same circuit fused by the 7.5A backup fuse under the hood.
But most likely you'll first have to find the short that cooked the fuse to begin with.
By ballistic
#104302
Yep, I was looking at a wiring diagram last night and saw that one, but I wasn't sure what it was for, I'll check it out later.
Thanks for the help :)
