ECU, Wiring, Sensors
By pete1civic
#81080 i just got a jdm d15b vtec and everything whent smooth them i turned on the car and it idle from 1000 rpm to 2000 up and down and im running with a p28 but they told to get the po8 ecu so know im confused can anyone help me out
By pete1civic
#81114 i check but i didnt found anything is there another way you could check it i heard if you apply wd40 what you think?
#81115 I agree, I dont think its an ECU issue. Spray WD40 on all the vac hoses and listen for a change in idle. Check IACV also.
#81123 People do use that ecu for the D15bs. Its definitly time to start checking for leaks. Hoses do go bad after a while and all of a sudden.
