- Sat Jun 11, 2016 2:37 am
#359290
So I just got me a 94 ex 3 days ago it seems in overall OK condition running wise but has some issues I'm finding . It has a few dents mainly fenders. it has a crappy front suspension on it. But I got the car basically free.
But anyway night before last I realized when I left my friends that my driver dude high beam doesn't work at all. The low beam is perfect. So today I went and bought new bulbs. The clips that hold the bulbs are still in good shape and both still have the rubber pieces over them . So I replace both bulbs and check them out and I'm still having the same issue with the new bulbs. So I put the old bulb I thought was bad in the passenger side and the high beam worked. So it's not the bulb at all. I cleaned the connector and put the bulb grease on it and still didn't help. I've tried shaking the wire and doesn't make it flicker or anything. I assume it's not the switch because the passenger side works perfectly. Any ideas? I figured its grounded or the low beam wouldn't work. I wanna check it tomorrow if you have any ideas please help. Which wire is for the bright so I know where to start
Thanks in advance.
Thanks in advance.
92' sedan z6 swap.
