- Wed Mar 23, 2016 5:33 pm
#358738
Hi Guys !
My civic EX Vtec 4dr. 4At. Used to have a oil leak on distributor O-Ring. I decided to change it, but after it was changed, I got engine check light No.4: Crankshaft Position Sensor.
But where is it located, why I can not find the spare part number ?
I took to the electronics garage and they said the sensor is into the distributor, and changed some wiring into the distributor, but still have same engine check code.
What could happen. Should I replace the whole distributor ?
I asked and seems that spare part is: TD42U / TD-42U / 30100P08006 / TD42. Is it right ?
I guess the electrician just damaged and swap a cable when replace some wiring.
I wonder if someone has comprehensive electrical plane and/or guide of the whole distributor wiring ?
Your valuable cooperation will be appreciated as I am located in Bogota, Colombia. Thus, in case of part replacement I must import the whole piece, that would be expensive.
Thank you !
Thank you !
